- Apr 7, 2005
At least I think it is coming from that direction. The location of the sound is somewhere around the cpu to power supply.
When I turn on PC 2 in my sig, it boots up fine with no chirp noises. If I stress all 4 cores, it will start chirping. If I stop stessing the cpu, the chirping goes away immediately. The sound is a high pitched whine that goes in and out. I tried stopping the PSU and the CPU fans while the computer was running and it did not help. Not sure if it is the fans causing it. Another odd thing is that after stressing the cores for around 5 minutes, the chirping just goes away and won't come back till I restart the computer. The power supply and video card are old ones that I have used for years without an issue. New parts are the CPU, MB, RAM.
