I lost my power cable for the Ultra 600W power supply. Talking about the fat cable that plugs into power supply and wall socket shown in bottom the image
I found a cable like that in my mess of cables, but it was connected to a brick type dc adaptor. The plug says 10A 125V. I also found another cable that says 10A 250V and temp as 60C/75C. Will I be able to use these cables for the PSU ?
I checked the wire connected to my other PSU, it is a lot fatter and also says 10A/125V and has temp mentioned as 105C.
The PC that connects is Athlon II X2 , HD 4670, 1 HDD, 4GB DDR3.
If not where can I buy a similar cable ?
