eastbaybeast
- Jul 30, 2007
Okay, so here's the deal:
my power supply blew up. Took out only my hard drive (tested on a different rig to verify its dead). Totally sucks, but at least everything else (well, almost) is fine (also tested on different rig).
However, upon getting a new hard drive, the blowout also seems to have screwed the SATA hard drive controller on the mobo limiting it from detecting any kind of hard drive plugged into the mobo on bootup. I have checked on a separate rig that indeed the new hard drive does work as well as the SATA cables.
anyways, here is my question: barring buying a whole new mobo, cpu, vid card, and memory deal (my current setup is a socket 754 agp pos which would require a total overhaul if i had to replace just the mobo) would it be possible just to buy one of those cheap SATA pci cards in order to detect the hard drives? that would be a lot easier on my empty wallet atm. also, the mobo is no longer covered under warranty so rma is out.
suggestions?
thanks
suggestions?
thanks
