Power supply AX850
x2ezx
I want a sli of Asus GTX580, just want to know if my Corsair AX 850 is enough.
thanks!
You'll be just fine as those above me stated. The AX850 is a very good PSU with plenty of power for your proposed load.
Would it Tri-SLI GTX 580 though? That's an extra 50W per card compared to GTX 680, right?
I wouldn't recommend running tri-SLI 580s on the 850. It can probably handle it in a pinch, but you'll likely exceed its capacity in high stress scenarios.
