Power supply advice
woel
Hi!
I'm going to buy a new PSU for my computer. I searched this forums to get some clues about what to get. Initially I was aiming for an antec truepower 2 480W since it seemed quiet and powerful. After reading some posts on this forum about some problems with asus and antec I got a bit confused.
I have an Asus A8N-E and I want a new quiet and powerful psu. Can anyone give me a good tip. I don't want the most expensive. The truepower 2 480W or something in the same price range.
Thankyou!
/L
you should be fine, the problems seems to lie with the antec HE's , AFAIK there isnt a problem with the truepower 2.0
Yeah. You're good. I use a lot of A8N's in all of their flavors and have never had a PSU issue with any Antec or any other brand power supply... other than the HE.
Thankyou for the quick reply. Then I will get one as soon as I have the money. :)
Btw, how much can I trust the voltage monitor in the asus utility? I get 11.7V with my current psu. That seem a bit low.
/L
You can't really trust any of the monitors... They should only be used as a vague point of reference.
/L
The Antec TruePower & TP II lines have no problems that I'm aware of, they are very good PSU's.
You must use a DVM/DMM to measure voltages, BIOS/software are just about useless.
Good Luck,
Dave ;)
