quantum112
- Jan 20, 2010
Hey folks. I have a question that's more in the electrical domain, but since it concerns speakers, I'll put it here. I have these 8" studio monitor speakers that have always popped a bit when turning on - they've been working fine for a year and from what I read on certain models this is normal. However, the left one popped a lot louder in the past few months and I couldn't really trace it back to anything specific.
The other day I turned on my CRT and noticed some kind of vertical bars of alternating brightness scrolling up the screen and from what I read this was indicative of a ground loop - that's when I began to question my wiring.
I have two power strips that all my PC stuff is connected to, each in its own wall socket. One of them is a classic power strip, and the white one has an on-off button that lights up when it's plugged in and "on", looks almost exactly like this.
The classic one had only my PC plugged in and the switch one had the speakers, display etc., and stuff worked except for the excessive popping. So I thought I'd switch the strips so that the left speaker was the only thing plugged into the switch-strip and everything else in the classic, and when I turned on the left speaker... HOLYF***TURNTHATOFFRIGHTNOW. Some kind of loud drilling noise, is the best way I can describe it. Distortion of some kind. This wasn't any kind of normal interference which is relatively quiet, this was jackhammer level (they are 140W).
My only guess is that the switch on this white strip is causing some kind of breaking up, almost as if turning on and off 100 times a second, causing the amp to freak out. This is a really cheap power-strip from a generic store, all the other ones (without switches) that I've bought there work fine.
I got rid of the switch-strip and plugged everything into classic strips and the popping is a lot quieter. The speaker, luckily, doesn't seem to have taken any damage. What I'd like to know:
1) Technical explanation of what the hell happened there?
2) How come, plugged into another wall socket and with more load on it (monitor, lamp, printer, etc.) the switch-strip didn't cause any crazy stuff to happen with the speaker (except the loud pop @ power on)?
3) Is it possible for something like this to affect and actually damage other devices like displays, PSU's, etc.?
Thanks
Thanks
