Power requirements for a 6800 GT?
TekViper
Read that nvidia recommends a 480watt psu for the Ultra's, what about GT's? I currently have a 330watt enermax, not going to even try it on a GT. I'm looking at antec trupower supplies and i can get a 430watt for $76 shipped or a 480watt for $90. Think a 430watt would be enough? Trying to save a few bucks if the 480 isnt nessacery.
Currently i have a p4 1.6 @ 2.4ghz, 2 HDs, 2 optical, 3 fans, sound card, tv tuner.
hmm really? So you think i could run a GT on my current 330watt enermax? Do you have a link to the power requirement spec?
The minimum for the 6800U is 350w so a name brand 330w PSU should be fine for a 6800 GT.
I have a 350W Enermax and it easy runs my system. Good brand name PSU's like enermax will run an Ultra on a 350W nVidia only specs so high cause the generic ones are crap.
Ya 330 will do ya just fine :)
Ditto
You can get away with a quality 350W PSU with a 6800U OC (probably)
yeah 330 would be fine....i would bump it up to a 350 or 400 if your an overclocker with many extras in your box
I run an enlight 430watt w/2 80gig, 2 cd's, 4 fans, TT volcano9+, and a 6800 GT OC with no probs
sweet thanks for the info. I guess ill try it on my 330watt enermax and not get a new psu just yet. Anyone got some actual spec sheets on how much power these cards are using up?
Cool link. When i put in my system w/ a 6800 GT, it says i should get a 344watt PSU. Now im not sure if i should run everything off my 330watt enermax.
