Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a power supply from a Sony monitor. The power supply is a Powernet PWI1904S. The main switching transistor has passe d away. Can anyone tell me the part number of the transistor please.
dENNIS
By the fact that the d in your name is not capitalized, I think you have caps-lock on. Make sure to turn that off next time you post, otherwise it's considered rude/shouting.
I think you will have much better luck trying to google that question. Unless someone has the exact same monitor, or a monitor that uses the same power supply, and is willing to take it apart for your sake, which doesn't seem very likely to me. Then again, I could be wrong.
