Are there any good threads around here about power? Right now I'm having to use multiple locations for my rigs to avoid possibly popping the circuit. If I use a kill a watt device and measure how much each rig is using at the outlet how many watts can I safely stack on each circuit?
This week at some point I will be building shelving racks and mounting fans flush against the racks both pushing and pulling air over my precious video cards.
Where I am building is in the same room as the circuit breaker and in close proximity to the furnace. Some might call it a closet but I grew up with a bedroom that size.... I will be putting in dedicated circuits straight to my shelving units and I'm trying to figure out how many I need to do. I planning on going all out and mounting a monitor on the rack and later on adding a KVM but its just not in the budget right this second.
I will be running the basement fan 24/7 to send the heat upstairs where it is needed. I've already closed and even taped off the OUTWARD flowing vents that are in the basement to stop the furnace from wasting any heat down there.
