To hook up the power light and the HDD light i know you have to hook it up to the mobo but is it color coded and what if you don't have some of the colors to hook it up? or do you just put it in any color?
the cords are labeled but the motherboard is not labeled and i put the one that says PWswitch on it and the power switch works but i put the power led on it doesn't show the light the mobo has different colored ones but not all the colors match up with the cords.
mobo pin colors wont match wire colors. what mobo do you have? the wires from the case/led is color coded for positive and ground (common). the color all wires share is the common color, indicating ground, or negative. the mobo manual should tell you which pins are for what function, and which of those pins is positive or negative (be sure to align the picture in manual with pin1 on mobo).
These things are usually laid out in the manual. Worse that'll happen if you plug in backwards is they won't work. Easily fixed by flipping them around.
