DusanV said:LOL, for a sec I was scared you might actually do it...
280Z28 said:If I did, I bet rubbing alcohol would take it back off without any side effects to the panel at all.
m0unds said:aside from solvent etching on the plastic of the display and possibly permanent discoloration of the led..
i'd just stick a small piece of electrical tape over it if it won't dim
Eagle156 said:Open the monitor case and take the LED out of there.
chiablo said:You could always solder a resister between the LED and the monitor.
Of course, this is probably more risky than the black marker idea.![]()
