Power LED blinks on newly built PC
trumpet-
Hi everyone, I just built a PC with parts from newegg (athlon x2 64 3200+, msi mb, ocz 512mb ram). I have nothing plugged in but the cpu, and ram (it has onbaord video). When I push the power button, the cpu fan spins for about 3 seconds, then stops. The power LED on the front of the case blinks on and off about every 3 seconds. I've taken the motherboard out of the case to see if it was a short, and it had the same behavior. I've also swapped the power supply and saw the same issue. Anyone know what this could be?
Make sure the cpu is seated in it's socket correctly. Bad ram could also cause this problem, try a different stick if you can.
depending on your power supply sometimes the extra 4 pins on the power supply to mobo connector that are now required can get sideways and not plug in the correct way and may be causing your problem - also are you getting any kind of beep code?
I tried a different stick of ram, no luck. I have a 24 pin pwoer supply, so there aren't any pins that go unused, if that's what you are referring to. Also, no beeping at all. Is it possible that the HSF being put on 180 degrees backwards can cause this?
If the HSF isn't in good contact with the CPU, then that could cause a shutdown. However, it really sounds like a short/power issue.
Does your video card have an aux power connecotr on it? And is it plugged in?
Did you remember to plug in the "P4" connector? It's a small 4-pin connector that plugs in near your CPU.
Did you test the PSU to see if it is working properly?
Is your RAM plugged in the whole way?
As was mentioned before, try reseating your CPU.
