Power Issue? Locks/Stuck At Reboot For No Reason
GeForceX
System:
  • Antec TruPower 2.0 430W
  • Asus A7N8X Deluxe
  • AMD Athlon XP 2500+
  • Corsair XMS PC-3200 512 MB
  • Seagate Barracuda 7.2K IDE 80 GB
Facts:
  • Absolutely no floppy/CD/DVD/flash/media drives.
  • Everything in a single outtake rear fan and a Zalman CNPS-7000.
  • Temperature reports 87 F on CPU and 85 F on ambient.
Issue: Computer locks up and/or is stuck on reboot every 3 hours to 2 days on very random occassions.
Story: This was a computer I built a while ago. This had been an ongoing issue for me for a while but I never had the time to tackle the problem. This computer will freeze for no reason basically. I had a 350W Enermax Silent PSU earlier and it would crash. I thought it was the PSU so I replaced it with the new Antec 430W PSU and turns out the issue is the same. I'm not sure why really.
Anyone care to shed light on this issue? :'(
-J.
Check RAM stability with Memtest86, particularly multiple passes of Test#5 and Test#8.
Run the proper HD diagnostic (Seatools for Seagate drives?) to check for weak read/write HD magnetic properties.
If Vcore setting is marginal, voltage-droop under load could be the problem. Just bump Vcore up one step in BIOS. Same applies to Vdimm.
Hope this helps!
