Power external enclosure with PC PSU
Ensign.Fodder
I know that the power bricks that ship with external drives are simply providing 5V and 12V power so it seems I could modify the cable to accept a standard IDE molex. The reason I am trying to do this is I have several old HD's in enclosures that have old pictures, OS images, crap I cannot delete, but I do not want to have them in my case, and I do not want to have 5 bricks plugged in all the time.
I know someone has the knowledge and I am sure I could hack this out but life and family are a bit much now.
Thanks for any help.
You could pull the drives and use one of these.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822999161
or this if you can find one in IDE(assuming the older drives are IDE)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817707127
I'm still having trouble figuring out how making an external enclosure take a molex connector would save you time or allow you to not have them all plugged in at the same time. Maybe you could elaborate some more.
I would personally just buy a larger external drive and move your files to the new one.
I've done it. You need some soldering tools, connectors, wire, and a multimeter. ;) Have fun!
Another option is to simply get one 5.25" external enclosure and use a removable HDD bay inside it, making it easier to switch out the drives. If you're extremely lazy, buy extra drive caddies.
I am trying to take the external enclosure existing power cord (4 pins around a center block) and modify the end that connects to the power brick (which connects to the wall/power strip) to use a standard IDE molex instead of the brick.
Here is a article that talks about doing the same thing.
Link
Did this - Hitachi Deskstar 7K1000 1000GB Hard Drive - 7200RPM, 32MB, Serial ATA-300 for 109.99 + 1.99 S&H + 7.57 Tax = $119.55
30.00 MIR - M$ Cashback 16.50 = $73.05
Plus the ThermalTake enclosure @ $24.99 + FS - Link
So total $98.04 for 1TB External drive without brick which will eliminate 3 (possible) bricks.
Thanks for the ideas.
