I've been considering a new power supply for my main rig and retiring my old Enermax 650 to server duty. I've read a lot of good information in here about requirements and whatnot.But since ive read that PSU's operate best and live longest at between 40%-60% usage I was considering going with a fairly large capacity unit like a 1kw.
Now that being said i'd like to find out about a few more comparisons. I dont need specific scientific data but id like to know..
1. If i upgrade to a 1kw versus my existing 650w, Should my PC still draw roughly the same ammount of power from the wall?
2. Because in theory it would be putting less of a load % on the PSU would the 1kw generate less heat than running the 650w at closer to capacity?
I realize it's sortof an Apples to Oranges comparison since I dont have specific model #'s to compare but Would probably go with an Enermax or Corsair PSU as they both seem to be fairly well built and reliable.
The current system with the 650w (which im looking to upgrade the PSU in) is a Core i7 at stock speeds (dont plan on overclocking but I may slightly at some point), 4870x2, WD Velociraptor 300gb, 1xDVDRW, And 5x 120mm fans.
Any advice would be helpful.
Shane
Shane
