I am using one of these external USB/ESATA drives with a WD 1TB Black HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16817392016
I am using it with an Asus P6T Deluxe Motherboard and the ESATA port does not support hot swapping so if i connect it I have to restart the machine for it to be detected in windows also i read that you should not even connect it while the computer is on if the port is not hot swappable.
It works greats but the problem is that the drive is always on and spun up and running very hot, I don't access it much but don't want the hassle of restarting the machine when i want to power it down or access it?
