Power cuts on boot
KINgGh0sT
Applicable hardware:
ocz 450 watt PSU
Asus A8N-sli mobo
Thermaltake kandalf case
amd 64 3500+ 939 venus core with a couple pounds of zalman copper sitting on top
So here's the cringe part: my case fell over. It fell 90 degrees so Mobo was face up but upon trying to boot power cuts after a second. Don't even get a boot beep.
First reaction was something got bumped and shorted so I ripped my case apart so it was down to PSU and Mobo and the problem persists, no loose parts in the bottom of the case either. Yanked the mobo out to make sure none of the backside pins were bent, looked fine.
I've pretty much established something is wrong with the PSU, mobo or CPU. I get power, fans spin for a second and cut so I figure it's the mobo detecting something wrong and killing the power.
Any opinions or insight is greatly appreciated.
I'd be pretty suspicious of your cpu and mobo.. particularly with a gigantic heatsink, might have fucked up the cpu and the socket.
Just a thought.
Just a thought.
I'm leaning towards the same thing, failed boot attempts are usually, but not always signs of a deceased mobo. Do you have another PSU to try?
