w1retap said:I've had this laying around for a while.. I forget where I downloaded it from.
haven't a clue.. all you need is a good power supply with some headroom and good 12v amp ratings.DemoMode said:actually thats the one, do you have an idea of the entire system specs that are running on those?
did you even look at the link he posted?? it has the x1900 and 7900 series on there. it also goes into detail about the system they used.DemoMode said:Thanks but im looking for the ones that include the latest cards such as the X1900 series and 79xx series
SandTiger said:So which is to be believed? That chart which states that the 7900 GTX draws 267watts at full load, or xbitlabs which shows a 84watt max load. Thats one hell of a difference.
