Power Consumption
jkfde
Would the 180 watt power supply in this case
SD-101
be able to power, 2 ssds, ODD ,MSI 85i mini itx motherboard, tv tuner, and 16gb ram?
Are you talking about the MSI B85i motherboard? Highest wattage CPU is 84W. SSDs take maybe 2W while writing, under 1W idling. You should be fine. I doubt you will ever use over 100W even if you attempt to push your system.
Note that I said should, because the quality and topology of the PSU is unknown. However, even if it only put out half of what Tt claims, you will probably be fine.
Ya, thats the Motherboard. Would the ODD and the tv tuner affect those values?
The only thing it says on the psu is that its a "180W PSU and Active PFC"
