S
splinter3k
Guest
Hey guys, I haven't built an AMD system in a while, but I just ordered a Foxconn board and Sempron to put a cheap system together for a friend. I know on Intel systems you can ignore the PEX/4-pin molex connector on the mobo if you use a 24 pin power supply, is the same thing true for nForce 4 boards?
Also, I don't need SATA drivers on Intel boards for non-RAID setups, true on nForce 4 boards as well?
