Power connection help!
ChRoNo16
My Asus Maximus III Gene has an 8 pin connector for the cpu power, but half is blocked with a plug. Should I remove it and use all 8, or four?
remove plug, use your 8 pin power plug.
the 4 is only covered for older psu without the 8.
