Powder Coating
ereshkigal
Question for the experts out there. Going to powder coat my case inside and outside. How do I protect the screw holes or when I get it back just send a couple dummy screws in to clean the threads out?
Ya just re tap it. If you want certain areas protected though, ask them to tape certain parts.
They will plug and mask anything that you need protected, its just a simple matter of putting a silicone plug into a hole or thermal tape or a cap on a screw or machined area. I will add this to my FAQ
