My network is set up as so:
Cable modem in my neighbors apartment
His WiFi router (not sure of model) connected directly to that modem
Cat-6 cable running from Ethernet port of his WiFi router to my apartment
Same Cat-6 cable connected to my Linksys WRT54GL v. 1.1 running DD-WRT v24-sp2 (10/10/09) min
My apartment is served wirelessly by this WRT54GL
My problem is that I can't get port forwarding to work. I've tried w/Tomato Firmware and now DD-WRT with no luck. I have set up port forwarding multiple times in the past w/no problem (different routers, not this one but it's nothing special set up wise). My computers are running Win7 and OSX 10.4.
I've run port tests from various sites and they always say that the port is blocked (connection timed out or refused, message seems to vary). I've tried changing the port numbers, even tested with just port 21 for FTP, and no luck.
My assumption was that being plugged into his WiFi router w/Cat-6 was similar to being connected to a hub but now I'm wondering if it is in fact doing some routing and affecting my port forwarding.
Do I need to do some sort of chained port forward? ie. forward from his router to mine and then to my computers?
Anyone have any ideas? Oh, I should mention that the cable modem only has 1 ethernet port on it so plugging into that is not an option.
Thanks!
Thanks!
