You should probably check the internal clearances, make sure the 5-in-3 you choose is not so long that it will bump up against something. Also, some cases have permanently attached metal "guides" in the bays that may inhibit inserting a 5-in-3.
There's no reason this 9-bay tower wouldn't work for a 15 drive tower, is there?
I would replace that power supply if you decide to purchase that case. It's presumably garbage and I wouldn't risk 15 drives to it.
