Potential Motherboard/Power Switch Problem
kreber
First off let me begin with the original problem. My computer would not display anything when the power switch was pressed, however the computer sounded like it was running and all the fans were going. I tried new ram, video card, and power supply with no success. I have since then replaced the motherboard. Now I can get the computer to turn on and display everything, but when I turn the computer off, I must drain the power by switching off the power switch on the power supply and wait 30 seconds. This does not always work but I would say it works about 60 percent of the time. When it does not work it seems to have the same problem my old motherboard had by running everything but not displaying anything on the screen. I have also tried a different power supply on the new motherboard and get the same display/no display about 60% of the time. I feel as though I have tried everything that could be wrong with the system other than the case, which could be a problem with the power switch. Would a faulty power switch produce the intermittent problem? Thanks for the help in advance.
