consider me a hardware newbie. the last pc i built was an amd athlon xp 2500, which i overclocked to 3200. i haven't really kept up with things.
heres the kit i have taken delivery of:
Intel Core 2 Duo E4500 "LGA775 Allendale" 2.20GHz (800FSB) - Retail
Gigabyte GA-G33M-DS2R Micro ATX (Socket 775) PCI-Express DDR2 Motherboard
OcUK 4GB (2x2GB) PC2-6400C5 800MHz DDR2 Dual Channel Kit
2x Samsung SpinPoint S 160GB SATA-II 8MB Cache - OEM (HD161HJ)
Arctic Cooling Alpine 7 Pro CPU Cooler (Socket LGA775)
Antec EarthWatts 380W PSU
this is my first multi-core system, and my first intel system too.
questions:
1/ the motherboard tells me the cpu is running at 2.2ghz, windows tells me its running at 2.2ghz, and cpu-z identifies it as a 2.2ghz chip...but i am confused as to why the 'core speed' is currently sat at 1200mhz. i have seen this very occaisonally flip up to 2200mhz. i am aware that this chip is capable of speedstep, but i have disabled this in the bios...
any explanations?
2/ i am a little confused about the memory. as far as i can see, i've bought 2x 2gb 800mhz ddr2 memory...yes? cpu-z tells me this:
any explanations?
3/ i got xp pro, drivers, windows updates and logmein installed whilst i was at home so i could login from work to carry on setting things up. for no apparent reason the computer completely locked up on me...twice. i came home at lunch to find the pc completely non-responsive, just displaying what i was doing at the time...reset it, all was fine...went back to work - did the same a couple of hours later...got home, same story. at the moment i am running everything at stock...any suggestions?
4/ i would like to have a go at overclocking, but i really don't know where to start these days...all i had to do back in the 'olden days' was fiddle around with the fsb to get a 400mhz overclock. the thought of tinkering with the voltages supplied to the cpu and memory worries me a little. any advice that you can give me with regards to upper limits i should be aiming for would be really useful.
many thanks!
questions:
any explanations?
any explanations?
many thanks!
