PostgreSQL Full text search question.
Mcot
I have a postgres database that has a few tables with columns of type TEXT. These columns store unstructured text.
I want to be able to search the text columns for specific things and also be able to do full text searches. After reading the documentation on the postgres website I can successfully perform ft searches on the columns, but I am having trouble pulling out specific things.
For example lets say in my unstructured text I have some URL's. According to this document http://www.postgresql.org/docs/8.4/interactive/textsearch-parsers.html the default full text parser for postgres will specifically parse URL's. But how do I perform a query that says, "For this table, give me every row where the text column contains a URL.?" I have a feeling I should just use regular expressions for this, but the ft parser is already parsing URL's so I was wondering if there was a way to sort of use it for that.
Also, what if I want to pull out something that the default parser does not look for? I can't seem to find a lot of information about how to extended the parser and add new items.
I know I am trying to use the ft search for something that its not EXACTLY intended for, but if it works it would make my queries a lot easier.
I'm familiar with the full text search of PostgreSQL, but from the examples in the manual it would seem the parser returns a table. If you would use subselects to extract the URLs, then you can most likely check whether it the column that contains subselect results has the value you want. There will be a performance penalty using subselects this way, but it could work.
Posting the query you have so far would help.
If nobody else gives you any more hints, I suggest you ask this on the PostgreSQL novice mailing list, you'll probably get a good answer there, almost certainly faster than here.
Hi, thanks for the response. I found that i can do what I want to do with regex queries and it works OK, so I think I am going to stay with those unless I see a huge performance problem. I have been asking around on the postgres IRC channel and no one seems to know a whole lot about full text search.
The documentation on the postgres site as a whole is awesome, but I find the fts documentation to be a little less friendly than the rest. I will try the mailing lists through, that's a good suggestion.
FTS in Postgres is a recent addition to the official distribution (since 8.3); it used to be included as a contrib module called 'tsearch2', and appears to have changed very little. Knowing that might help you find more information, but I'm afraid I don't have an answer to your question. It seems like it should be possible.
Code:
SELECT alias, description, token FROM ts_debug('foo-bar-beta1');
      alias      |               description                |     token
 numhword        | Hyphenated word, letters and digits      | foo-bar-beta1
 hword_asciipart | Hyphenated word part, all ASCII          | foo
 blank           | Space symbols                            | -
 hword_asciipart | Hyphenated word part, all ASCII          | bar
 hword_numpart   | Hyphenated word part, letters and digits | beta1
The above query is the only query that I can find that returns the actual alias that the particular token matches.
ts_debug is obviously supposed to be used for debugging.
From a high level perspective I want to return all urls in a column, so I want to use the full text parser to create tokens for me given a column, and then return all the tokens which matched the url alias.
