- Nov 11, 2012
I used Dataram RAMDisk, but decided to try out some others. I don't even know if they exist, anymore. You can do a 30-day trial with Primo Ramdisk, and AIM Toolkit is open source, but isn't very fast.
For these tests, I'm using 4x32GB DDR4 memory overclocked to 3600MHz at 18-22-22-42-2T at 1.35V's. Gear 1 and BCLK frequency at 100MHz. I set my RAM amount to ~64GB.
The fastest by far is Primo Ramdisk.
My Dataram RAMDisk is version 4.4.0.36, but it's still not bad.
AIM Toolkit, an open source Ramdisk, was "slow"... at least compared to the others.
For DDR5, 2x16GB DDR5 memory overclocked to 6400MHz at 36-48-48-104-1T at 1.35V's. Gear 2 (it's a cheap pre-built MB) and BCLK frequency at 100MHz. I set my RAM amount to 16GB.
Primo Ramdisk:
Primo Ramdisk:
