Post your Heaven Benchmark Scores (Single GPU Only!)
murkris118
Post your Heaven Scores here. Please mention Overclocks and temps during your runs. Do minimum of three runs to make sure your overclocks are stable.
(updated) Matrix 7970 Platinum at 1310.
you guys made me go ahead and hit the red button. oh no!!!
and an action shot because i know you guys love your hardware pr0n.
That`s fucking awesome. Heard the 7970 Platinum was epic but did not know by this much!.....
MSI TFIII 7950 @ 1231mv/1215mhz/1850mhz. Core loads at 72-74C, VRMs stay below 80C.
Powered by Unigine Engine
Heaven Benchmark v3.0 Basic
FPS:
66.5
Scores:
1675
Min FPS:
24.8
Max FPS:
125.4
Hardware
Binary:
Windows 32bit Visual C++ 1600 Release Mar 7 2012
Operating system:
Windows Vista (build 6002, Service Pack 2) 64bit
CPU model:
Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
CPU flags:
3292MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT
GPU model:
NVIDIA GeForce GTX 670 9.18.13.1033 2048Mb
Settings
Render:
direct3d11
Mode:
1920x1080 fullscreen
Shaders:
high
Textures:
high
Filter:
trilinear
Anisotropy:
16x
Occlusion:
enabled
Refraction:
enabled
Volumetric:
enabled
Tessellation:
extreme
Unigine Corp. © 2005-2012
Saw that other 670 and 2500K system only do 49 fps? No oc at all on that sys?
FPS:
66.5
Scores:
1675
Min FPS:
24.8
Max FPS:
125.4
Hardware
Binary:
Operating system:
CPU model:
CPU flags:
GPU model:
Settings
Odd that you got such a high score with such a low minimum fps and low max fps.
How on earth did you get 66.5 fps? Did you have AA at x8 or some black magic on your rig!? Mine is a 680 overclocked like nuts! but I get only 55 fps.
Please stick to the same settings as in the OP. Any results not using those settings hould be removed to avoid confusion.
I love these threads. Where is the ruller to measure my ePeen?
FPS:
66.5
Scores:
1675
Min FPS:
24.8
Max FPS:
125.4
Hardware
I have the same hardware. my OC is 1280 on GPU and 4.5 on CPU. No way you are getting 66 avg witht the same system on MAX settings. Also, my min and max are higher than yours.
I thought my score was high too. I will have a look at the settings again. Probably no AA or some such.
Yeah. Run it again with everything on high.
If AA is on it will say:
1920x1080 8x AA Full Screen
If no AA is on it will say
1920x1080 Full Screen
Right. Mild oc at 4.2 and +122% power target, +100 Gpu clock offset and +400 Mem Clock offset on Evga Precision X
FPS:
48.3
Scores:
1216
Min FPS:
24.7
Max FPS:
117.5
Hardware
Binary:
Operating system:
CPU model:
CPU flags:
GPU model:
Settings
Render:
direct3d11
Mode:
1920x1080 8xAA fullscreen
Shaders:
high
Textures:
high
Filter:
trilinear
Anisotropy:
16x
Occlusion:
enabled
Refraction:
enabled
Volumetric:
enabled
Tessellation:
extreme
I prefer my first run :p but I noticed I did not use AA so I post another time with AA and clocked a bit higher
I can get CPU to about 4.3 but I need a fair amount more voltage 1.41 to 1.47 to do so but is alot faster :p
Uploaded with ImageShack.us
can anyone here run the benchmark on a 680 with stock clocks? i just want to compare my score with a stock 680
Setup
Results
GPU is an Asus DCII HD 7950. It needs 1193 voltage to do 1210|1691.
try copying my settings and do the run see the difference, I am curious :)
1920x1080 8x AA
shaders high
textures high
trilinear
anisotropy 16x
occlusion enabled
refraction enabled
volumetric enabled
tessellation extreme
34.9 fps score of 879
9.1 80.8 min-max
