Post your DREAM computer!!
I'd like to see that AGP card put in a PCIe slot, hehe.
My ultimate system would be FX55, some SLI NF4 board, 2x BFG 6800 Ultra PCIe (if they have 'em), a couple gigs of corsair, 2 raptors, phasechange cooling (on CPU, NB, and GPU, why not? its ultimate right :D ), PCP&C 510 SLI PSU, and some case... thats all. oh, maybe some optical drives too, those come in handy sometimes
EDIT, oh I forgot about monitors, how about a few 2001fp's or whatever. as for the Audio, I'd get some soundcard, whatever... um... a sunfire ultimate reciever, and the latest klipsch Reference series speakers with 4 RSW-15's, heh.
A8N SLI
FX 55
2 WD RAPTOR (1 FOR SYSTEM, 2 FOR PAGE FILE AND OTHER STUFF)
2 VANTEC VORTEX HD COOLERS
6 400GB HD
6 3.5" WATER COOLING COOLERS
2 6800 ULTRA
2 WATER COOLING PUMPS AND RESERVOIRS (ONE FOR HD, ONE FOR EVERYTHING ELSE)
DANGER DEN EVERYTHING ELSE
TWO OCZ POWERSTREAM 600 PSU
THAT HUGE LIAN LI CASE
4GB RAM
PLEXTOR DVD DRIVE
PLEXTOR PX716A DVD WRITER
20.1" SCREEN WITH 16ms RESPONSE TIME
P4 3.6/8
Intel Board
1GB RAM
1 36GB Raptor for boot drive
1 400GB SATA drive for data
4 Dell 2005FPW's
Just off the top of my head.
Original poster: Why did you choose ECC ram for a board that doesnt support it? Do you know how to configure a system?
mine:
FX-55
2 gigs of G.Skill GBLE
a 74 gig raptor
meeeh. i guess a 6800 ultra.
DFI's S939 when it comes out
Any old generic case
Davo818 said:
I nvever knew you could put 6 harddrives on 1 comp
The A8N-SLI Deluxe has 8 SATA ports, plus 2 IDE. If one wanted to use external optical drives, one could put 12 hard drives on it, 8 SATA plus 4 PATA. :D
Tyan K8WEX (S2895)
2x Opteron 250 (or 252, if available)
4x 512MB OCZ PC3500 ECC, 2 per CPU
4x Raptor74, RAID10 for OS
8-Port RAID controller with H/W engine, 32MB Cache (Raptor RAID)
16x 7K500 HD, RAID5 for files
16-Port RAID controller with H/W XOR, 512MB Cache (7K500 RAID)
2x GeForce6800Ultra, SLI
OR
Custom-built VGA, using cluster of X850s (probably at least 4)
2x 243T (or replacement)
1x Qualia-004 projector
Logitech Z5500
Audigy2ZS Platinum Pro (Dammit, I always forget sound!)
Cooler Master Wave Master
2x 16x DL DVD+/-RW (NEC, probably- I don't like Plextor)
2 x Opteron 250
Tyan Thunder K8W Chipset Dual-Cpu Motherboard
16gb or Corsair ECC Registered Memory (8gb per CPU)
24 x Sata 300gb HDD running through 2 x 64bit 3ware SATA RAID Controller running Raid 0+5
SuperMicro Rackmount Server Chassis (with Hot-Swap PSUs)
2 x Optic Fibre NICs + 2 x 1gbit Ethernet ports (onboard)
Floppy drive :)
DVD+CDR/W slim drive
UPS
No idea what i'd use it for, probably just telehouse it and run a business of it haha.
I'd have said an 8 x 850 opteron server but their a tad expensive, each chip is like $1000US at least :p
If you want realisitc then i'd say an Apple G5 Dual 2.5ghz Tower with 24inch Apple Display
Why not? I'm running 12 of them. There are hundreds of servers that run 100S of drives
LianLi Makes a case [the v2000 and v2100] that has 12 hidden 3.5" bays, + 7 visible 5.25" bays..
Does it have to be with parts I can afford?
If not.. then here goes
4 x opteron 250
16 gb registered pc3500 [it exists, folks, just very expensive]
36 x seagate 400gb sata drives in raid 5.
3 x 3ware 9500S-12 cards with 1gb ecc cache each
4 x wd raptor 74s in raid 0 [as swap file drive only]
8 x ST373454LW [15k rpm, 73 gb single platter] in raid 1+0 as a boot drive
1 x adaptec 2230
a non existant motherboard that has 4 x pci-x slots
2 x pci-e x 16 slots
2 x pci 32 bit slots
a 1000w+1000w+1000w 3way redundant psu that can hold all this
a case that can hold all this.
2 x ati fireGl v7100's in the pci-e x 16 slots
1 x http://www.9xmedia.com/Images/CONFIGURATIONS - COLOR/2 over 2.jpg with the 23.1" option.
2 x pioneer 109D's
The keyboard I have now
a larger wacom intuos2 tablet than my 6x8
mavalpha said:
Tyan K8WEX (S2895)
common misconception..
While opterons definately benefit from ECC.. it's not what they require
they require REGISTERED memory, which is NOT the same as ECC
You're system wouldn't even BOOT
Dual 30" Apple Monitors
SLI Nvidia 4400 (they are out in a month) (they both have 512mb ram, so that is 1gb video ram)
Dual Opteron 250
Tyan SLI mobo (was at CES)
16gb ram pc3200 eec ram
2 15k scusi hd. (one for system, one for page file and other stuff)
25 400gb Hard Drives (10tb)
All water cooled.
Two OCZ Powerstream 600w HD (One for CPU, MOBO, GPUS etc.) (One for 10tb array)
Would get two Lian-Li PC V2100 Black Aluminium Full-Tower
Saw of the right side of one and the left side of the other and weld together.
Gut the inside of one, and create a huge Hard Drive rack on one side, and on the other 2 water cooling pumps and reservoirs and radiators for water cooling the entire system.
The DVDr, DVD Rom, Floppy Drive.
fuck that give me a quad operton mobo with sli and 2 6800 ultra extreme editions on pashe change cooling with an ass load of raptors and id be happy
Can you find any OCZ PC3500 ECC that isn't registered? I'll save you the trouble of running a search...
OCZ said:
#2- OCZ PC-3500 ECC Registered Dual Channel DDR
While I am sure you know more about servers than me, I still suggest cross-checking your information in the future; I try to do this whenever possible to avoid putting my foot in my mouth.
Also, I'm sure you are aware that Athlon64-FX (the 940-pin variant) is almost identical to Opterons. Their memory requirements, for example, are the same.
OCZ PC-3500 ECC Registered Dual Channel memory has been designed and engineered to take full advantage of the AMD Athlon 64-FX platform.
OCZ fully validates each PC-3500 ECC Registered EL DDR Dual Channel memory kit on the Asus SK8N mainboard to ensure maximum stability and performance.
If you own an AMD Athlon 64-FX system and want the absolute best in performance and stability, look no further than OCZ PC-3500 ECC Registered EL DDR memory.
* This product has been specifically designed for use on the AMD Athlon64 FX platform and should not be used on any other desktop platform. AMD Athlon XP and Intel Pentium 4 users should not purchase this memory for use on their systems.
The man (YOU) SAID
"OCZ PC3500 ECC"
You did not Type "OCZ PC3500 REGISTERED ECC"
As I never buy OCZ products, I did not look to see if Y)OU made a mistake between ECC and REGISTERED.
See?
Not only am I aware of that, but it is my cause for contention that the only truly fundamental difference between opterons and fx's is a cache change, an smp change, and the lack of a 940th pin on the 939 models
Shall we agree that we both jumped to conclusions on this one, and share the blame? As you said, most people don't understand the difference between ECC & registered; I didn't want to create any confusion, so I listed the more commonly recognized feature- my fault for omitting the other aspect. However, I am well aware of the more stringent demands of a server-class processor.
Overall, I am still quite satisfied with my choice of components. Do you agree that it is an otherwise respectable parts list?
in workstation performance, is quad any better than dual proc, or does that ony make a difference in server apps?
my dream computer:
DFI LanParty nF4 SLI
AMD64 FX-55
4 x Crucial Ballistix pc4000
2 x GeForce 6800 Ultra
200Gb HDD
Audigy 2 ZS platinum
Plextor DVD-RW
Lian Li pc-75
Yes, it's very good.. - I'd opt for corsair's part, but that's just me.
No, it makes a difference in any app that can support it.
Maya, for example, is not a 'server' app
There is a diminishing rate of return, mind you
If 1 processor runs maya at a baseline of 100
2 might give you 180pts
3 might give you 240
4 might get you 300 [numbers could be even lower]
but you get the idea..
But we aren't talking about $ logic.. We are talking about dream computers for rich fellows who like to waste $
4 processors are better than 2.. 2 are better than 1
Converseley, 4 processors are better than 1.. Just not "everywhere"
Farcry doesn't care..
Unfortunately....
No such board exists like I want it
(2 x pci-e 16, 4 x pci-x, 2 x pci, 4 x opteron)
THe best "useable" board out there in my opinion is the s2885
1 x agp 8x
4 x pci-x
1 x pci
2 x opteron
8 x dimm slots
The s2895 is nice with it's dual pci-e-16 slots, but it's not "out" yet.
2 x pci-e-16
1 x pci
3 x pci-x
So..
I'd have to limit myself to only 2 3ware cards (making it 24 x 400gb sata seagates in raid 5)
and 1 adaptec card
and probably have to limit myself to 16gb of pc3*2*00 ram (8x2gb registereds)
http://2cpu.co.kr/zboard/zboard.php?id=2DEX&no=111
Nice picture collection of that board
4 x opteron 250
1 x adaptec 2230
2 x pioneer 109D's
fucking drool
how much would this cost? (estimate)
FX-55
Asus A8N-SLI
Dual 6800Ultra BFG
2 74 Gig Raptors
2gigs of PC3200 OCZ El Platinum Revision 2
Chenming Dragon Case (Dunno I just love that case)
PCP&C 510 SL
Some sound card, audigy 2? I don't know sound cards.
The best surround speakers money can buy.
The 23 or 24 inch Samsung Monitor from Newegg, (its like 2 grand or so)
Liquid Nitrogen Cooling on my cpu.
And a nec 3520A drive.
I leave anything out? Oh and a really comftorable chair!
EnderW said:
fucking drool
Well
The opterons themselves : $3400
The memory : ~$7000
The seagates? : ~$14000
The 3wares : ~$3000 [with the memory in that #]
The raptors : $680
The Scsi's? ~ $3500
Adaptec card ~ $600
if a motherboard like I wanted existed, I'd say ~2000 for it.
another $1200 or so for that PSU
~$800 for a case
$1600 for the video cards
$20,000 for the monitor
$200 for the pioneers
$300 for the larger wacom
So, around 60 grand considering I'd want a decent UPS for it, too
Now.. a system that I could actually justifiy? I already put that together.. it's only $17K
what use would you put it to to justify 17k???
as for my "dream" hardware, dual opty 252's w/ 4gb ram and 2 6800u's in SLI. refrigerated water cooled. raid 5 of 5x 400gb hitachis, cuase i dont need anymore ATM(or for a good long while), with 2x 74gb raptors in raid 1 for boot. dual nec 3500a's, cuase they're awesome drives, pc p&c 510 express.
oh, and dual 21" LCD's
Heavy video editing. Massive data storage. 3d Rendering at a decent pace. Large display setup
2 x Samsung 243t's is in and of itself $4,000
1 quadro fx can be ~1500
Also, read my thread in the data storage forum.. I'd say you'd be smarter getting 5x400gb seagates than 5x400gb hitachis
Hitachi = No advanced RMA's, Difficult to get a hold of tech support dept, 3 year warranty
Seagate = Advanced RMA's, easy to contact tech support dept, 5 year warranty
40% more warranty, and 50% faster rma time for 10% more seems worthwhile to me.
i didnt know the seagates were out yet :p
yes i will agree that seagates would be better
for what end? ie, what do you do for a living?
My friend and I actually priced one out on Newegg a while back. It came out to $7000. Dual Opertons, 6800 Ultra, over 1 TB in RAID 5 in 300 GB HDs, a controller card for said HDs, 2 Plextor DVD writers, 4 or 8 GB of RAM (depends on the mobo we ended up with). I suppose now you'd have to go back, do dual Xeons with dual 6800 Ultras.
http://www.newegg.com/app/ViewProductDesc.asp?description=22-148-063&depa=1
~378.04 shipped to me...
Maybe the stuff I mentioned it's going to be for?
I'm not saying I have this rig that would be 17k, what I meant by "i built it already" was I've already put the 'quote' together..
The system in my sig is my best personal rig.. I haven't even gone 64 bit yet, for my personal machine
My dream system is the one I currently own:
FX-55
ASUS A8N-SLI Deluxe
2x6800GT BFG PCIe
4x512 Corsair 3200 XL
2x74GB Raptors
400GB Seagate
Audigy 4 Pro
PCPC 510 SLI
Lian Li PC-2100
Sony 52x52x52x16 CD-RW/DVD
Plextor 716SA
Logitech diNovo Media Desktop
Sennheiser HD650s
Belkin Wireless Pre-N
well, the things you mentioned, editing video and graphic work can be used in different fields, like games, movies, graphic design, ect, just knowing that youre editing video and doing high power graphics work doesnt tell what you are doing it for.... im not trying to be an asshole or anything, i was just curoius; that is one hell of a system you justified, and it would be pretty cool if you were a pixar artist or something :D
i know, i checked out your sig when you said that, i figured you just had it on a waiting or "wish i could have this" list, ive priced out many systems that there is no way in hell i could afford :p
Major_A said:
One that upgrades itself.
Like this:
Model:
Valerie (female) - $59,000
  • Description of the Valerie android
    Human appearance (with tether)
    Height - 5'8" without shoes
    Weight - about 150 pounds
    Silicone skin
    Skin, hair, and eye color are buyer's options
    Primary power is pressurized air via a tether​
  • Included equipment
    Base station equipment
    2.4 GHz desktop-type PC
    1 GByte RAM
    80 GByte Disk
    17" Thin screen display
    Color printer
    Internet interface (NIC card)
    Pneumatic compressor system​
    Software
    Windows XP
    IBM Via Voice
    AT&T text to speech synthesizer
    Custom AI programs including the following:
    English language parser
    English language interpreter
    Household assistant behavior programming
    Learning capability
    Multiple AI data bases
    Internet search interface
    Image processing software
    Image recognition library
    Depth perception programming
    History file​
    On-board equipment
    400 MHz PC-104 computer
    2 Color CCD video cameras
    Microphones for hearing
    Speaker for speech output
    50 foot tether​
  • Required from owner's home
    120 V AC Power
    High speed internet access​
  • Capabilities
    Muscle movements equivalent to a human
    Understands spoken commands
    Responds to owner via spoken words
    Sense of touch
    Default programming for household servant
    Artificial intelligence
    User programmable
    Internet access​
  • No cost options (circle one each)
    Eye (iris) color
    Blue, Lt Brown, Dk Brown, Gray, Green, Violet​
    Hair color
    Black, Blonde, Brown, Gray, Platinum, Red, Silver​
    Hair length
    Short, Medium, Long​
    Skin color
    Caucasian, Asian, African-American​
    Primary language
    English, Japanese, German​
  • Available options
    GPS receiver - $1000
    Custom face - $3000
    Secondary language - $1000
  • Terms of sale
    Initial deposit - half down ($29,500)
    Delivery - currently 6 - 9 months after purchase
    Customer acceptance - one month acceptance period
    Final payment - upon acceptance ($29,500)
    If not accepted, then deposit will be refunded.​
    Warranty and support​
    Valerie will carry a one year warranty against mechanical failures. Within that period she will be repaired free of charge. We will also offer technical support by phone during normal business hours (8 - 5 US Central time) Monday to Friday. We will also offer a maintenance contract - no details yet.
http://www.androidworld.com/prod19.htm
