Post Your Core 2 Duo Temperatures
pogipl
I'm seeing a lot of threads of people asking i am overclocked is this temperature right. If you guys can post your temperature's of your setup it would help a lot of people and even me.
CPU:
OC: (If any)
Stepping:
Week:
Code:
Vcore:
Cooling:
Cooler brand/model:
Case brand/model:
Motherboard:
Bios Version:
RAM brand:
RAM rated speed:
RAM actual speed:
Latency:
Ambient Temperature:
Idle Temperature:
Load Temperature:
you should add ambient temps in here because mine are like 3 degrees lower from the cooler weather this time of year
CPU: e6600
OC: 400 x 8
Stepping: B6
Week: L630A
Code: forgot
Vcore: 1.325v
Cooling: Air
Cooler brand/model: Zalman 9500
Case brand/model: Lian Li PC-S80 w/ 3 Silverstone Fm121's installed
Motherboard: Asus P5W-DH Deluxe
Bios Version: 1503
RAM brand: Corsair
RAM rated speed: DDR2 800
RAM actual speed: same
Latency: 4-4-4-12-2
Idle Temperature: 43c
Load Temperature: 57c
temps taken with coretemp
room temp: 18c
ambient inside case: 31c
CPU: E6400
OC: OC'd to 3096mhz 387x8
Stepping: B2
Week: 31 (Pack date: 11/01/06)
Code: A611
Vcore: 1.325
Cooling: Air
Cooler brand/model: Thermalright Ultra 120 w/ 120mm Scythe S-flex 1600rpm silent fan.
Case brand/model: Antec 1040
Motherboard: Gigabyte DQ6
Bios Version: F7
RAM brand: OCZ Platinum Rev2 2GB
RAM rated speed: 800mhz
RAM actual speed: 387x2
RAM voltage @ 1.9v
Latency: 5
Room Temp, i dunno, but its 37°F outside right now, and im inside with just shorts on :\
Idle Temperature: 32°c-34°c Somewhere around there, forgot to take note, its at full load right now.
Load Temperature: 47°c
Here's a screenshot right now..
Running at 3.2ghz adds about 3-4°c but not Orthos stable(need to find correct setting to run this stable) , had it last as much as 21minutes. But can run SuperPi 32M all day long with no issues. Vista is stable as well and had played Ultimate Alliance with it no problem.
here's CPUZ for it - http://valid.x86-secret.com/show_oc.php?id=141475
Update: It is now idling at 24°C room temp is about 18°C right now cuz its freezing outside.. 0°C
This thread is flawed, you will have people posting there Motherboard monitor temps while others post there core temps, you need to specify what you are after.
hes right.
Try to ask for iTAT idle, iTAT load,
or coretemp or sumthin. Bcuz all the responses will be quite varied.
But it's big and messy w/ 80% of the folks using mobo temps...I'm one of them. This thread has the potential to be ridiculously thorough and detailed. :D
CPU: E6400 Lapped
OC: 400 x 8
Stepping: B6
Week: L625
Code: A301
Vcore: 1.325v
Cooling: Air
Cooler brand/model: Tuniq Tower 120 w/ Scythe SFLEX E 49CFM, 21DB, 1200RPM
Case brand/model: Stacker 810 2 Intake, 2 Exhaust, same SFLEX E as above
Motherboard: Asus P5B Deluxe 1.03G, C1
Bios Version: 0804
FSB: 1.30V
NB: 1.45V
RAM brand: Crucial
RAM rated speed: DDR2 667
RAM actual speed: DDR2 800
Latency: 3-3-3-8
VDIMM: 2.4V
Temps: Core Temp
Room Temperature: 25C
Idle Temperature: 40C
Load Temperature: 50C
CPU: e6600
Stepping: B2
Week: 30
Code: B013
Vcore: 1.3v
Cooling: Tuniq Tower 120
Cooler brand/model: stock tuniq
Case brand/model: Antec P160W
Motherboard: P5B deluxe
Bios Version: 0804
RAM brand: Crucial
RAM rated speed: DDR2 PC5300
RAM actual speed: DDR2 PC4200
Latency: 5-5-5-12
Ambient Temperature: 25'c
Idle Temperature: 34
Load Temperature: 45
All temp by Intel TAT
Another Temp at Higher speed. E6400 at 3400Mhz
CPU: E6400
OC: 425x8
Stepping: B2
Code: A611
Vcore: 1.392
Cooling: Air
Bios Version: F7
RAM rated speed: PC6400 800mhz
RAM actual speed: 850mhz
RAM voltage @ 2.11v
Latency: 5
Room temp: 24°C
iTAT core temp
Idle: 44°C
Load: 57°C (Orthos Small FFTs)
Load: 64-66°C (iTAT workload 100%)
Motherboard sensor
CPU temp
Idle: 30°C
Load: 49°C (Orthos Small FFTs)
Load: 53-55°C (iTAT workload 100%)
