System Specs:
Asus A8N-SLI Premium
AMD 64 3800+ Venice
2x 512 Corsair XMS DRR RAM (Tested in other PC - working)
Antec Phantom 350W (tested, working)
2x Asus Extreme GeForce N6800 256MB (tested, working)
1x S-ATA WD Raptor 35GB 10'000 RPM (tested, working)
1x IDE WD 400GB 7'500 RPM (tested, working)
1x IDE Maxtor 40GB 7'500 RPM (tested, working)
So, heres the problem.
I built this rig about 4-5 months ago. It was running very smooth until ~3 weeks ago. I turned it off during the night (which very, very rarely happens, I usually only restart, the rest its running 24/7) when I tried to turn it on in the morning the POST stopped after loading the CPU, (There are no errors displayed, nor any vocal POST errors) it just stops.
So after a few hours of moving around hardware in 3 Computers, a few bashes on the desk it decided to go back to normal and boot as if there never was a problem.
So today I get up, going for the regular morningly restart, and its happening again.
I cleared the CMOS, tested hardware again, searched google, nothing helped.
The system has never been o/ced more than 5%, and ever since it happened the first time I never o/ced again.
I might add that we got extreme heat here atm, (around 30°C) and the PC is somehow podested in high in the room, which I guess makes it get alot of outside heat....
Cheers.
AMD 64 3800+ Venice
Cheers.
