Nummy sarcasm.Borgschulze said:Whoa, that's one of the nicest photo's I have seen in a while.
No, it actually is, I like technical art, and stuff with a low area of focus.Volucris said:Nummy sarcasm.
I saved it in my picture folder.ChingChang said:Yeah, it is a pretty good image. Possibly the only image of a zalman cooler that I actually like.
revenant said:yepp - done that... they seem to max out at 1365 or 1370... 1350 is good to go all day and night though.... very solid. I think if I used AS epoxy I might gain a few extra mhz... but it's not worth the hassle ATM.
it's a little gehtto, but the 80mm --> 60mm adapter helps funnel the air really well, so it hits the cards hard, and not too much of the surrounding areas. I am thinking up a more elegant design for it...
MrGuvernment said:k, first you say something you CANT buy in a store, but then you say something like an ATI silencer......
So which is it
The ramsinks look awesome, but what about the gpu lol. I think it needs some kind of coolingmaicoX said:
alik4041 said:The ramsinks look awesome, but what about the gpu lol. I think it needs some kind of cooling
revenant said:pre-filling the loop
post-fill
w00t.
happy belated valantines day!!!! <3stryder2720 said:92mm Delta on a VF-700Cu..ignore the date I'm too lazy to change the date
http://i4.photobucket.com/albums/y139/stryder27200/100_1464.jpg
PNY 6800GT running 450/1100 @ 65ish load
Happy Hopping said:what kind of SLI bridge would say LAN party on it?
l0cke said:[IMGhttp://img218.imageshack.us/img218/7523/picture037sized4fo.jpg[/IMG]
old celeron heatsink cut up and put on a s3 ViRGE
alik4041 said:hmm...I cant tell from the picture but do you have a place for the hot air to escape? it looks like all of them are headed at the ram sinks. Just wondering.
[snip]
wow very nice.. are those metal tubes? Looks goodmaicoX said:Hi
http://www.hq-modding.de/bilder/maico/cippX/Bild-597.jpg
]http://www.hq-modding.de/bilder/maico/cippX/Bild-590.jpg
Holu said:
CletisMckloskey47 said:ghetto but kind of effective
took a pci bracket, screwed an old amd fan to it, and positioned it so it would blow on my 9800 pro
