Hi all,
New member here looking for some assistance. I've trawled around google a bit and not really had much joy, so thought I would try here.
I just dug out an Abit KR7A-133R motherboard that I own, with a project idea I had in mind. It used to work fine when it was my main PC, but since I upgraded to an Athlon64 it's been defunct.
So I got it out, lobbed in some PCI cards for network and sound, and away I went. Except I didn't get very far!
The PC always hangs after "Updating ESCD ... Success" when I first put a PCI card in, or at the same point where it would have said that if it's a reboot as it doesn't have to update the ESCD. It will never get any further. If I remove the PCI card and boot again, it will boot fine.
I've tried a PCI card in every slot on the motherboard; they all do exactly the same. At the moment, I'm testing it with a card in PCI slot 3 so that it is not sharing any hardware interrupts with anything else. Nor is it sharing any software interrupts according to the POST screen.
I've tried reflashing the BIOS with both the oldest and newest releases; I've tried resetting the CMOS using the jumper; I've tried forcing ESCD updates. I've also tried turning off all the various PCI-related enhancement settings in the BIOS with no success. I haven't seen any BIOS options to disable the internal or external cache which is another tip I came across whilst searching this forum.
I suspect this board may have bitten the dust, but before I throw it in the bin, I wanted to make sure...
Have I tried everything?
