Post GPU Folding Temps
Jon855
[H]ard DCOTM January 2008
My Configurations:
Core 1 : idle/95%
Core 2 : idle/95%
GPU : low/100%
CPU Load temps - 45c Sythce Ninja 120mm 94CFM
GPU Load temps - 75c @650/750/3dVolt - Zalman CU 900 cooler
Are they within the norm?
Not an expert. But those numbers sound about like others I have heard.
I'll post when I have mine up.
Mine stabilize at 70. Room temp of 78F, and I have the HIS heat piped cooler.
Voltage at 1.45 and core at 640.
Mine looks within the norm range... Thanks.
Wow that's a high voltage. I thought ~1.4V was the stock 3D clock voltage.
Stock cooler and fan settings and 3D clocks at 1.4v, I see mid 80s. With the fan @ 50%, 70s.
mhouston, I think he was saying 3D voltage not 3vots.
Stock speeds/voltages, according to Madshrimps OC guide in the FAQ, are:
# 625MHz on the core @ 1.425v
# 750MHz on the RAM @ 2.089v
My X1950XTX settled around 57 degrees as reported by the CCC after about 3 hours of gpu folding.
Jon855 said:
My Configurations:
Core 1 : idle/95%
Core 2 : idle/95%
GPU : low/100%
I am using stock cooling on my 1900XT and the same settings you have. It topped out at about 76C when folding and 59C when idle. Room temp was about 21C.
EDIT: I should have mentioned these temps were with 2D clocks
This is of course based on the one time I actually got it to run. :confused:
<EDIT2>
It seems to have fixed itself while I was at school :D
Also here are my temps in 3D mode @ 621/720
GPU - 91C
Room temp 27C
</EDIT2>
My computer rebooted itself overnight (I think it was because of a windows update) and it hasn't worked since. It seems to hang on either "Starting GUI" or verifying one of the checkpoint files.
zim01 said:
I have no idea..happy damn thing works :)
More likely. ;) Aren't we all damn happy that Marty's getting his ass whipped this week by me
Don't forget to run it in 3D mode! I had nothing but problems running it in 2D mode.
kicking mary03's ass????? how/where
To put this quite simply, he isn't GPU Folding for HFC this week... and I am :)
Very interesting.....thanks! I figured it would just run slower but I'll try and put it in 3D mode when I get home.
Then someone is going down! I'm not sure who.....but someone is going down :D
I am pretty sure that no one should be GPU folding for the Bowl...
There's nothing in the rules that says I can't. Only one instance of folding :) This has been cleared already...
AtomicMoose said:
Since it's becoming a big thing all of the sudden, for the purposes of keeping it fair, GPU boxen aren't going to be allowed, so before anyone asks, maybe next year.
and you really don't want to screw with p[H] :eek:
Am not screwing with him, I told him about it and he said it's fine before and now he's changing the rules... -_- I don't like him one bit...
Edit: I told him about it before the GPU Client were even released... I guess we just did not antipicate this kind of mass raping of marty yet.
