Finishing buliding up a new comp for a friend...
Asus P4C800E Deluxe
P4 2.8C
Mushkin lvl 1 2x512 pc3500
Antec True power 430 ps
Did a reformat of his hard drive and tried to install windows xp. Kept getting fatal errors and it would get progressively LESS far through the process. Finally starting giving a BSOD.
I pulled a stick of RAM and after that it installed successfully. I still need to run MEMTEST to verify the stick of RAM is bad (or put it in my comp and check it).
However, the computer continues to appear to boot up kind of slow...
On top of that, ever since the first install, it has given a POST error of 1-1-2, which my guide lists as "Your motherboard is having problems". Now this is also "4 beeps" which the manual says is an error with the motherboard timer.
What do I need to look at? Is the mobo bad...? Some jumper setting I am unaware of...?
Thanks for any help
Asus P4C800E Deluxe
P4 2.8C
Thanks for any help
