I'm thinking of getting an i7 build before I go off to college... Note: I am also considering a C2D build, or a Phenom, if the price/performance ratio is good.
Gaming (100+fps in CSS would be good), and music making
Less than $600 would be ideal
3) Where do you live?
Mass
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, RAM, MOBO, PSU, I may upgrade GPU later..
GPU (8800GTS 320), HDD 250gb, Case, Soundcard.
6) Will you be overclocking?
Yes
Have a 22"
Before the end of the summer...
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
None in particular
10) Do you already have a legit and reusable/transferable OS key/license?
Have XP 32, but I'm going to get W7 64bit.
Current build:
AMD 4600 @ 2.6
Corsair 2gb 4-4-4-12 @ 667
Asus M2N4-sli mobo
EVGA 8800GTS 320
Antec 900
Rosewill 550w PSU
Thanks.
Mass
Yes
Have a 22"
None in particular
Current build:
AMD 4600 @ 2.6
Asus M2N4-sli mobo
EVGA 8800GTS 320
Antec 900
Rosewill 550w PSU
Thanks.
