::Thermaltake TPG-750::
::ASUS Crosshair IV Forumla::
::AMD 1090T 3.7 Ghz (OC'd)::
::Thermaltake Frio::
::XFX 6950 2GB::
::G.Skill Flare 4GB DDR3-2000 (2x2GB)::
::WD Caviar Black 640GB (OS)::
::Windows 7 Ultimate 64-bit::
The problem is I get this really weird system hang only when I do a certain set of actions. While I play Bad Company 2 everyone once in a while I have to alt+tab or alt+enter to do something in the background and to get out of full screen mode to do something on Command Center, Teamspeak or lookin something up real quick.
Here's what will happen: The screen will go black, ambient noises from the game will still play in the background, sometimes the noises will do the stutter effect as well. Then the noises will stop, screen will stay black for 1-2 minutes. Finally something will start to appear either a white screen first or white back ground with game in windowed mode.. Then slowly my system will come back to life and be fine... Time elapsed would be around 3-4 minutes.
Just 15 min ago, this happened again (the whole system hang process) but this time the screen smeared in colors and then blue screen with the physical memory dump thing.
Now a couple of things you need to know:
-This would usually happen after I played more than 3 rounds. The first 2 rounds or so I wouldn't have this problem.
- This also happens when I exit the game (exit game through main page) but only after gaming for extended periods of times (8+ rounds)
-Right before the white screens I will hear two window sound notifications that tell me a device has been unplugged (you know like if you had a usb stick in and you took it out, windows plays a default sound right? That one.)
-Teamspeak will disconnect (or timeout) then reconnect as my system gets itself together.
-I'm usually disconnected from the server that I was on in-game(BC2).
-I have Installed various versions of the drivers (10.10, 11.1, and 11.1a) resulting in no difference.
-Yes I did you driver Sweeper in Safe Mode.
-I keep my fan speed on Manual 50%.
-I never had this problem with my XFX 5830, alt+tabbing and alt+entering were instant.
-I haven't reformatted yet.. but will probably install a separate OS on a a separate drive to see if the problem persists on that setup if you guys think I should.
::XFX 6950 2GB::
