Possibly adding fans to Asus Vento case
Dutt1113
I really like the Asus Vento case. I was wondering if anyone knows if you can add more fans to this case. I heard that you can add a 90mm opposite the one side mounted inside the case and 2 60mm fans at the very front on the inside of the case. I also heard that you can take off the air duct/tunnel on the side of the case that funnels air directly onto cpu and add yet another 80mm fan. I was always iffy about the cooling in that case but if i could add the fans i was talking about then I would definitely get one. But then again, with a good 120mm exaust fan in the rear of the case, it seems like that would be enough to suck a lot of cool air in through the two huge vents in the front of the case. It seems like their wouldn't be much air resistance in those vents.
