Possible To use a desktop at a server.
Konner15
I have a business and i want to do a certain something, can you tell me if its possible.
I want to be able to have people run an application using my data from a server.
I want to build a computer using a kit i bought and use that computer as a server without buying $600 server software for that computer.
I have a bunch of pictures and i have someone make a website for me using those pictures to send to a client, the person im sending it too doesnt want to buy the software i need him to use.
So i need a server that someone can run my application off of and use my files without sending them to them specifically, and they wont be at my office so i would need it accesible from a distance not just a wireless network
is this possible?
Konner15
Remote desktop for part 2 if it is running Windows 7 Pro or Ultimate pretty easy. Connection speeds and application types will dictate. Going super-awesome would probably be RemoteFX in Hyper-V plus RDC.
I don't like remote desktop because the person can then access all the files on my computer and im kind of a security freak
then its not really possible for them to run a program if they refuse to get it for their own computer...
do you just want to share files? or run a program on the "server"
i know its possible to run a program off of the "server" my school does it with their server.
I just dont know how to do it.
I would like them to be able to access the photo files i put onto the server and then be able to run the program from the server.
I dont know if this is possible with my setup
