Possible to take apart mouse??
Goat
hey guys.......I've got a Microsoft Intellimouse 4.0 and i love it to death, most comfortable mouse i've used. anyway, the left click button feels like it's going out. for example, when i go to double click something, it won't always register. I looked around the enclosure of the thing and couldn't find any screws. is it possible to open it up? are the screws under the surface pads?
..........ok
yes that i can take it apart? or yes the screws are under the pads....
also, whats the easiest way of taking off the pads without destroying them.
Goat said:
..........ok
I replaced the red led witha bright Blue 6000MCD and it has a blue laser with it glowing red in the back, just gently pri them off
with a knife
Goat said:
..........ok
Yes to both. I found the easiest way to remove the pads is too heat them up slightly with a hairdryer and use flat-faced tweezers (or a flat-head screwdriver) and pry gently while heating them up. At least that is what I did, or you could just use a razor blade to lift them up. Then I just glued them back down.
Hahaha, I just did this today to my Microsoft POS optical mouse. I wanted to have a blue mouse, so I went away with it =).
Its not hard at all to take apart or put back together. Just watch out for stray springs.
I took my microsoft mouse apart a few weeks ago in order to spray paint it. All is good now.
you could always just destroy the feet and get yourself some new ones from www.slicksurf.com
i think i got his first set of MX1000 feet and they are BADASS!!!!!!!!
