From what I understand the minumum storage for a new WHS install is somewhere in the region of 75GB or which it carves 20GB for a boot drive and the rest for storage into the 'pool'. Any extra drives added to the storage pool, whilst just being added as JBOD have data added to a standard NTFS such that if those drives are added to a different box they are readable. Now I currently run all my non workstation environments from VMs - with the VM boot disks in RAID 10 on one controller (A) and the data strores on a RAID 1 and RAID 5 arrays on a different controller (B). Hence I want to minimise IO on the VMs controller, A, and hence do not want WHS using the remaining 55GB as storage I want it to use the added VDs from controller B .
Is there any way to remove the 55GB from the storage pool or force it not to use it? (I am not worried about extra storage being used since the the VD for it will be set to autoexpand unlike my other VMs which have allocation at start).
