Possible to fix broken traces?
sandmanx
Has anyone here tried fixing broken traces on a board? I've got an old Epox 8K3A that has a couple of broken traces on the bottom. It happened when I took my waterblock off the board, the wrench slipped and cut 2 or 3 of the traces near the socket. The board doesn't power up anymore, but I was wondering if using a rear windo defogger kit might be a solution, if I can find a way to make the traces small enough.
I'll try to rememrber to post a pic of the damage when I get home later today.
Depends on how small the traces are, and how big the cuts are.
If it's a tiny trace and a tiny cut, using a conductive material should be enough (e.g., a pencil, drawn heavily between the two.)
If it's a bigger trace and a large cut, soldering a high-gauge (e.g., 30) wire between the two points works.
Both require a steady hand. If you're uncomfortable with either method, don't attempt them -- you can end up damaging the board further. Find someone comfortable with soldering small-scale connections (e.g., someone comfortable with hand-soldering SMT components).
In either case, use an X-Acto or similar razor knife to gently scrape the end of each broken trace, to expose the copper underneath. Otherwise, your attempts won't make contact with the conductive part of the trace ends.
The cut is less than 1 mm in length, but it did take that layer fo the board out of it. I think I'll give the pencil method a try and see how that goes. I am capable of soldering in wire, but I really don't enjoy working working with SMT, but I've done it before. Thanks for the feedback.
I'm not overly worried about getting this board working, as it's been in the closet for over a year, but it would be nice to get it working again as a HTPC.
Have serious doubts about the pencil trick. If you just need conductivity it might work, if its a signal line I would be suprised if it did.
In the shop we would work back down the trace and find a via (the hole that connects all the traces of the same circuit together between all the board layers, typically filled with solder. It looks like a little solder dot on the board that the traces on the outer layers end at.
there you can heat it up and insert a very fine guage wire and then hope for a via on the other side of the trace brake or to a component that the broken trace goes to. Sorry its hard to explain and we had scematics that told us where to find connections. Might not be applicaable to your situation, just depends on the board but a heck of a lot easier than trying to bridge it at the break. They had 10x microscopes to help do the work lol. twitchy stuff.
I get what you are saying. I'll give the pencil trick a shot, but I was having my doubts. I'll have to look at the board and see if I can trace the wires, they are damn small, and go to the cpu socket on one end, not sure where they end up though.
Where can I find some extremely small gauge wire? I'll stop by my local electrics shop when I leave work today, but I have my doubts they will have wire that small.
30ga. should be adequate. It's small enough for SMT pads.
I pick mine up at Fry's. I've also been known to use shielded wire-wrap wire.
Think Skritch hit it with the wire wrap wire, it normally has pretty tough insulation if memory serves, teflon I think. good stuff, and you could shave down the end going into the borad with an razor knife if you needed to. Filing that one away for future use :)
another trick is to find some pretty small stranded wire and at the stripped on end just use one or two strands but its a pain.
When working with gauges that large, I really tend to prefer solid core. Stranded wire at that size is a royal pain to work with.
