computerpro3
LightningRod
- Mar 29, 2003
Hello,
My system is as follows:
Amd CABNE Opteron 146 @ 3.1ghz XP-120/Panaflo L1A
Chilly1 Modified Prometia Mach 1 -59C idle (in the shop)
DFI SLI-D
2GB Mushkin Redline @ 260mhz 2-2-2-5 3.5v
2x EVGA 7800GTX ACS3 Cooling 490/1300
Audigy Platinum with Dantax Vision Two's
Custom Pc Power and Cooling 510 Deluxe SLI / Coolermaster ATC 101b
I think we all know that the 7800gtx's are hot little mofos, and my opteron is the cabne stepping, which means it loads in the 60's on air. ITs amazingly hot. When I get my phase change back, I'm thinking of selling it which will give me about $400 to drop on watercooling stuff. SO in the loop I need to have 2x 7800GTX's (which will be upgraded to 512mb ones in December) and my opteron, shooting for 3.2ghz.
Here's the thing, no way in hell am I giving up my Coolermaster ATC-101b. On the plus side, it can fit a 2x 120mm rad on the top easily, and it does have 5x 5.25 bays for a res and stuff like that.
Basically, is it possible to cool that much heat with one 2x 120mm rad? If so, what is the best performing setup from $400-500 that will cool my system? REmember, I'm going for max overclock, and there may end up being volt mods on the video cards.
Thanks.
DFI SLI-D
Thanks.
