I've got all the components for my new build except the Q9550 and 9800GTX which aren't in stock, so I've built it up and routed all the cables ready for when the last 2 bits arrive
my supplier says you should report any problems within 48 hours, so my question is can you turn on the power without having the processor and graphics card installed, just to see if the motherboard/power supply works, or will that do damage to the motherboard?
in the past all my components have arrived at once so I've never had to worry about this
