Possible problem with Maximus II Formula USB headers..
Damn Dirty Ape
I have the Maximus II Formula motherboard in an Antec Solo case. I used the USB connector from the front panel of the case and connected it to one of the on-board USB headers.
Some things will work when plugged into it, but some things won't. For instance a wireless keyboard/mouse receiver will work, as will a WDC passport 120gb, SD card adapter/reader(usb), but a 320gb WDC passport won't work. It will work however on the rear ports no problem. I've tried moving the USB connector around between the 3 USB headers with no luck.
I know the 320gb drive works, it does on the rear ports, as well as another desktop, and even a laptop. When I plug in the 320 passport to the front ports, the activity indicator will flash on for about 2 seconds then shut off. Works fine everywhere else.
I know the ports are 2.0 and the bios settings are for FULLSPEED and all the enabling things are turned on.
Do the USB port headers not provide full power like the rear ones do?
I have seen this happen on many cases, I think the problem lies with the quality of the cable more than anything else, If you use the included USB/Firewire bracket you will probably find the problem doesn't occur.
I get the exact same problem on my server and a specific USB hard drive I have.
hmm - I'll try the bracket on those headers today then. These front ports have worked on previous boards with this case, but stranger things have happened. Thanks!
