This is a good one for you networking gurus. Networking is not my strongest suit but I'm not a complete idiot with it by any means.
Here's the deal. I have a 40MB cable connection (yes 40, meaning up upgrade soon) and I use a VPN some of the time. I'm using torguard currently. I have several systems in the home, my desktop which is windows 11 connected by Ethernet cable to my router. my laptop and phone are connected by Wi-Fi as expected.
During certain hours and only while connected to my VPN service, my connection speed drops to anywhere between 5-20 mb. upload is around 1mb, should be 10. The weird part is this only applies to the desktop. I'd say it's the ISP throttling but why not my other systems?
I'm going over this with torguard support but so far they're about as helpful as a sack of hammers.
This seems to only occur between the hours of 2pm to 2am. Might be a little off on the time but close enough.
Turn off the VPN and all is fine. Is it possible they're throttling my desktop? Possibly by MAC address of the NIC? I'm at a loss here.
Tried resetting TCP/IP, reinstalled torguard software, reinstalled NIC. The usual steps. Router is an Asus AX92-U. Older model but just upgraded the firmware last night.
Any thoughts are welcome.
EDIT: forgot to mention, also tried to disable wifi on the laptop and plugged the same ethernet cable from the desktop into the laptop. speed was fine on the laptop.
