Hey Guys/Gals,
I have a dilemma, I currently have the below computer and I cant decide if I should wait for Nehalem or if I should upgrade now or cheaply upgrade now and save for Nehalem.
Old System
MB: Asus P4C800 Deluxe
CPU: 3.0 P4 1MB L2
Ram: 2 Gig of DDR 400
HD: WD 250 Sata
DVD Burner & DVD Rom old (ATA)
PS: 600 Watt with 35+ on 12V (I bought a X1950 Pro that Crapped out on me thats why I have a big PS)
VC: x850 Pro AGP 8X
I just bought my first house so I am a little money struck right now, so if i was to upgrade today I only want to spend around $350 and then save for Nehalem. But my current system is starting to show its age (usb ports power on and off all the time, I here the beeps from windows all the time) and it is really starting to bug me that I can not play some of the new games out since the x850 doesnt have SM3 (Bioshock right now).
If I upgraded with the below system do you think I would see decent improvements in Gaming and everyday stuff like CD/DVD converting/ripping. I will probably overclock the processor a little at a time until I get comfortable with OCing since I have never done it.
MB: GIGABYTE GA-P35-DS3L - $89 http://www.newegg.com/product/product.aspx?item=N82E16813128059
CPU: Intel Pentium E2180 Allendale - $79 http://www.newegg.com/product/product.aspx?item=N82E16819116052
Mem: CORSAIR XMS2 2GB (2 x 1GB) DDR2 800 - $34 AR http://www.newegg.com/product/product.aspx?item=N82E16820145034
GPU: XFX GeForce 9600GT 512MB -$149 AR http://www.newegg.com/product/product.aspx?item=N82E16814150277
Old Case
Old PS
Old DVD Burner
Old Hard Drive
Basically would it even be worth it to upgrade to the above system or should I just save up for a full upgrade with Quadcore, high-end board and what not.
Forgot to add I am using an older 19" LCD with a max Res of 1280 x 1024.
Also any possible alternitives to the above componets would be welcome.
Thanks in advance.
Rip
Old System
CPU: 3.0 P4 1MB L2
HD: WD 250 Sata
VC: x850 Pro AGP 8X
Old Case
Old PS
Old DVD Burner
Old Hard Drive
Thanks in advance.
Rip
