Quad QAM tuner DVR running two Avermedia Duets. It will also serve somewhat as a media server since it will also run Tivo Desktop for 24/7 downloading of recorded shows, services like Play On and TVersity, and a couple other Tivo services like Streambaby and KMTTG with encoding, assuming it can handle it all without hiccups.
$1000-1500 with everthing
3) Where do you live?
Tampa, FL
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Definitely motherboard and DVD burner. Possibly Intel CPU and memory and anything else I am missing
I don't know what I have that will be worth keeping for the new system. I have the following...
CM690
C2D E6750 with stock HSF
Three pairs of Crucial Ballistix in various speeds and timing. I believe they are all 2x1gb but one pair may be 2x2gb. I need to check the speeds and timings. I believe they all work but I don't know for sure since I don't have an extra board to test them on.
2xPCIEx1 Avermedia Duets Qam Tuners
Nvidia 7900 GS
Soundblaster Audigy 2 ZS
various sata hard drives
6) Will you be overclocking?
most likely no, but possibly in the future
2x21" CRT Viewsonics. I will probably replace them with at least a 24" flat panel eventually but they work fine so no real need right now.
B]8) When do you plan on building/buying the PC?[/B]
Soon.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Mainly enough PCIEx1 support to handle 2 dual tuner cards but also with the option to add more in the future should I choose. I don't see this becoming a new gaming rig since I plan to upgrade my main pc later once there is something I have an itch to play.
10) Do you already have a legit and reusable/transferable OS key/license?
Yeah I have a spare Vista Ultimate I can use though I will most likely just reinstall Win7 RC.
Also I have an Abit IP35 Pro board which is what has pushed me to do this. I originally ordered the Duets to play with a home built QAM DVR to help with conflicts on my Tivo HDs. Since the Avermedia Duets came in, of course I am now suffering C1 errors with the board and I can't even get it to post now. I have tried different sticks of ram in various slots with no luck. I even flashed the bios to the latest version which supposedly addressed the C1 errors. With Abit out of business I figure it is time to upgrade especially before I destroy the computer in frustration. The board never did like the Corsair HX620 from what I remember on the forums but I don't have another PSU to test out.
Tampa, FL
CM690
Nvidia 7900 GS
Soon.
