I think I may have a bent pin on SR-2, no idea how, thought I got it pushed back up a bit (used a sewing needle), well cant get booted without CPU0 disabled.....so tomorrow ill be looking again, looking for ideas on what the best way to tighten a pin.
Before its asked: I have no idea how the hell the pin bent, all I did was pull out an L5639 and there was a bent pin ... only thing i can think of is it being bent when I pulled the CPU.
Any help would be appreciated.
-W.Feather
Edit: For reference of people googling around, I know I saw no real good solutions out there on a quick search:
Solution - Be very careful with a utility knife blade, making sure to not break/bend the pin too much. I tried with a little sewing needle, Had little/no luck .... if you have good eyes you dont need a magnifying glass (i didnt have one)
-W.Feather
